CV axles going bad?
Old 08-13-2016 | 09:57 AM
  #41
slonny's Avatar
I did not have an intention to write a how-to in the first place. The pictures were posted for knowledgeable people to see what I am doing and correct me IF I did something wrong along the way, and also for others to learn from my mistakes.
Now that the project is complete, I organize everything, reduce the size of the images, and upload them to the site.
Old 09-03-2016 | 08:29 PM
  #42
slonny's Avatar
Oh man!
Originally Posted by slonny
Now that the project is complete, ...
or so I thought.
While replacing my front rotors and brake pads today, I noticed grease all over the passenger's side wheel well! One of the re-manufactured CV axles that I installed not so long ago had a torn inner boot. I guess, hose clamp cut through the rubber.
Detroit Axle offer life time warranty on this product (Front Passenger Side CV Axle Shaft w/o ABS for Automatic Transmission ONLY - USA Made - Lifetime Warranty - Detroit Axle). It is just a major PITA doing it all over again on the passenger's side.
Now I have to be very careful taking the stub shaft off without damaging the sleeve. I'll just follow donbrew's advice and use a muffler clamp (http://www.autozone.com/emission-con...uestid=5821765) and a small hammer. Bearing splitter (http://www.harborfreight.com/large-b...ator-3979.html) is a little bit pricey, but seems to be a safer option. Buy, use, return is another option.
Old 09-03-2016 | 09:56 PM
  #43
If you still have an old axle around, count the folds on the boot. I had a set that fit, but 1 less fold makes a difference, both blew out in no time. I seem to remember 5 or 6 was the number, yours seems to have 4. You could go to Advance/Zone and look at one they have in stock.
Old 09-03-2016 | 10:13 PM
  #44
slonny's Avatar
I still have the old ones laying around in my garage. Yes, it has 5 folds! The new one has only 3 folds. Are you saying that the old boot can be reused and the inner joint repacked with grease? I wounder if I need to take out the entire axle assembly out to do this? I begin to dislike Detroit Axle for some strange reason.
Old 09-04-2016 | 07:47 AM
  #45
Thing is you only save about $5 with them. I ended up at Zone, for $69 ea., IIRC. In stock.
IF you can find a new boot, you will need to pull the axle. They used to make a 2 part boot for VW that bolted together.
If it doesn't have 5 folds it will break, the suspension flexes too much.
Old 09-04-2016 | 08:39 AM
  #46
slonny's Avatar
I just checked other manufacturers of CV axles and they all have 3 folds on their inner joint boot (2011 CHEVROLET HHR 2.2L L4 Drivetrain Parts | RockAuto). It looks like mine just came damaged from the start.
Buying another one will not make a difference. I will just try to sort things out with Detroit Axle. In the worst scenario, I am covered by eBay buyer protection plan.
Old 09-04-2016 | 11:16 AM
  #47
You don't usually have to go to eBay protection, but any one with only 3 folds will fail quickly.
Look at the first photo for the why. It is not the clamp cutting it, it's the flexing.
$65 at Zone $70 at Advance; coupons available online.
Old 09-04-2016 | 01:08 PM
  #48
slonny's Avatar
Autozone sells only Duralast products. Here is the only one that fit HHR. It is exactly the same design as the one I got from Detroit Axle. Which $65 one are you talking about, donbrew?
Duralast Gold CV Axle 9553N- Read2Reviews onDuralast Gold #9553N
Old 09-04-2016 | 03:36 PM
  #49
The question is: is that a stock photo? Maybe it has to do with the length of the shaft, not the total length?
I just went to both web sites and looked in my zip code for in stock HHR axles. Cheaper brands by mail. That one is $64.99 in my Zone.
Not recommending anything, but this one looks like the Factory OE. There are lots of others. I had assumed they fit lots of cars, but only GM Delta.
CV Axle Constant Velocity Driveshaft See Compatibility Chart for Location | eBay
It was a long time ago for me; maybe it was the outer boot that split on mine. I do remember I noticed when I took them out of the box.
Old 09-04-2016 | 10:57 PM
  #50
slonny's Avatar
These CV axles are remanufactured and they cost as much as the new ones. Interestingly enough, the company that sell them is 15 minutes away from my house. But I am a bit hesitant to buy things from companies with little or no reputation. I'll wait for Detroit Axle to reply.
If I keep having problems with their axles, it will be a lesson learned for me and also a documented case for everyone else to learn from. It may be just my luck that I got a defective axle.
Quick Reply: CV axles going bad?
