Dash Lights Dimmer Switch
So I have this dimmer switch/knob/wheel on the center dash. When I spin it left or right the dash lights dim and go bright as normal. If I go full bright and beyond to the indent nothing happens. Normally this would operate the dome light. Is it suppose too?
Here is that post to make dome light work. As much a some want to think that all HHR are the same there not. Each year has it's own little quirts. We that own year one HHR know that more then most.
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-convert-2006-dimmer-turn-dome-light-7864/
https://www.chevyhhr.net/forums/showthread.php?t=7864
That's not something I really ever thought about in the 7 years we've owned ours. I just reach back and turn it on if I want it on. Generally speaking, it's not something that you'd do while you are driving and it's mainly for the rear seat passengers since the lights on the mirror are within fairly easy reach for the front seat passengers.
I'm actually a little disappointed in the whole lighting inside the HHR. I think there should be another dome light right above and slightly behind the driver/passenger like on most other vehicles. Mine has the sunroof option but I think you could still add a fairly flush dome light and wire it in with the rear. I think the wiring should clear the sunroof mechanism. This is something I will look into sometime in the future.
