Dash Lights Dimmer Switch
Old 12-04-2012, 09:39 PM
HHR
HHR's Avatar
So I have this dimmer switch/knob/wheel on the center dash. When I spin it left or right the dash lights dim and go bright as normal. If I go full bright and beyond to the indent nothing happens. Normally this would operate the dome light. Is it suppose too?
HHR is offline
Old 12-04-2012, 10:13 PM
oneton's Avatar
I don't think that 06 had that, There is a post on here somewhere that shows how to make it work. I had to do it to my 06 and my wife's 07. I will see if I can find it.
oneton is offline
Old 12-04-2012, 10:25 PM
oneton's Avatar
Here is that post to make dome light work. As much a some want to think that all HHR are the same there not. Each year has it's own little quirts. We that own year one HHR know that more then most.
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-convert-2006-dimmer-turn-dome-light-7864/
oneton is offline
Old 12-04-2012, 10:53 PM
HHR
HHR's Avatar
https://www.chevyhhr.net/forums/showthread.php?t=7864
Great! Interesting that the dimmer installed feels like it would work. Anyhow, I'll have to schedule that project. Thanks
HHR is offline
Old 12-04-2012, 10:58 PM
Oops. Sorry about that. Guess I'll just delete my previous dumbness.
firemangeorge is offline
Old 12-04-2012, 11:13 PM
HHR
HHR's Avatar
Ok, ordered switch. $20 at Rock Auto.
HHR is offline
Old 12-05-2012, 08:46 AM
@HHR, I hope your project will go smoothly. Please, let us know updates when you have this completed.
ChevroletCustomerService is offline
Old 12-05-2012, 09:17 AM
db/sb's Avatar
That's not something I really ever thought about in the 7 years we've owned ours. I just reach back and turn it on if I want it on. Generally speaking, it's not something that you'd do while you are driving and it's mainly for the rear seat passengers since the lights on the mirror are within fairly easy reach for the front seat passengers.
db/sb is offline
Old 12-05-2012, 09:46 AM
skyline26's Avatar
on my 08 it turns on the dome light, is this just an 06 thing?
skyline26 is offline
Old 12-05-2012, 10:22 AM
HHR
HHR's Avatar
I'm actually a little disappointed in the whole lighting inside the HHR. I think there should be another dome light right above and slightly behind the driver/passenger like on most other vehicles. Mine has the sunroof option but I think you could still add a fairly flush dome light and wire it in with the rear. I think the wiring should clear the sunroof mechanism. This is something I will look into sometime in the future.
HHR is offline
Quick Reply: Dash Lights Dimmer Switch
