Dont let this happen to you....
Old 09-05-2006 | 09:16 PM
oneton's Avatar
Key In Switch
I don't know if this is the place to put this ! If you can't turn key to lock look under the sterring wheel on the bottom side of the cover there is a little square that comes out with a light look up in the hole you will see a little elec.sol. [look to the left] just push it back with your finger or something and you will be able to remove key. will try to post a pic. of the the little take out plug soon
Old 09-05-2006 | 09:52 PM
TomsHHR's Avatar
This is why I carry a extra key with me..
Old 09-05-2006 | 09:54 PM
courthousedeb's Avatar
Same here...I always have one set on me no matter where I'm at. One set in my purse and even at car wash, the other set is in my hand or pocket.
Old 09-05-2006 | 09:57 PM
slamed87lincoln's Avatar
i know what your talking about...i found the pic in the owners manual after all was done
Old 09-05-2006 | 10:08 PM
TomsHHR's Avatar
And if you have a good key you can program another key.
I bought a spare so I have 3 and programmed the 3rd myself.
Put the good key in the Ign and turn it on, no need to start the engine.
take out the good key and put a key in to program, Turn the key on...
Then start the engine. It should keep running. Then spend the money you save by DIY on a
Old 09-05-2006 | 10:13 PM
oneton's Avatar
I know it is hard to do [ read the owners manual ] but there is a lot of info in it.
my wife thinks I am a nut case cause I keep all owners manuals and read them and HI light things in them for later fast look up. not getting down on anyone,just sometimes some of the post here, the anser. is in the book but you have to read it not just keep it in the clove box.
Old 09-05-2006 | 10:24 PM
If we did that oneton...we wouldn't have near as much to talk about.
Old 09-05-2006 | 10:43 PM
pontfirebird73's Avatar
Originally Posted by GRUMPEE
Maybe what he meant was don't put the key in the ignition to start it until after the jumper cable connections have been made. This would prevent any voltage spikes (from the intitial jumper connection) from wiping the programing from the chip. But then again I always thought the car system was programmed to accept the key...As I had to do with my 94 formula
your 94 formula actually has a resistor not a chip.
Old 09-05-2006 | 11:12 PM
GRUMPEE's Avatar
YUP, you're right it's a resistor
Old 09-06-2006 | 12:07 AM
Lee3333's Avatar
Whatever it is, new keys are expensive (I think about $35). You can buy a regular key without the chip (or resistor) and it will just open the door and not start the motor. Then, you can hide a real key in the car and carry the other one in your wallet (I cut mine down to make it smaller).
Quick Reply: Dont let this happen to you....
