Door chime keeps chiming
Old 12-11-2013 | 09:45 PM
thunder94's Avatar
keyhole. put the key in and wiggle it around and remove it a few times, see if it stops.
Old 12-17-2013 | 03:53 PM
mikiec's Avatar
I will try the WD40 trick tonight.
Report back in the AM.
Mike
Old 05-16-2022 | 09:29 PM
Toyasock's Avatar
Door chime when key is takin out of ignition
Originally Posted by donbrew
I wonder if there is a relay sticking somewhere.
I have this same exact problem and my check engine light came on one day and it wouldnt start after taking it to auto zone the code read engine control module every thing else on my car works just fine problem is only chime when taking out keys could it really be connected to the ecm
Old 05-16-2022 | 10:05 PM
Did you try the 2 possible solutions presented?
Old 05-26-2022 | 07:46 AM
Radco's Avatar
A interesting Old Thread :)
I am curious if anyone found the issue ?
So far no issue for me just would like to be armed if it happens to one of the family HHR'S :)
Old 05-26-2022 | 08:16 AM
Toyasock hasn’t been back since posted 05/16/2022.
Old 05-26-2022 | 08:35 AM
He's still trying to catch his breath after his long, run-on,1 sentence post.........
Old 05-26-2022 | 01:30 PM
A statement about codes, his hhr is just fine and a question about the ECM. Hmm, I’ll take dead battery for $600 Alex.
Old 05-26-2022 | 02:18 PM
We've seen much, much longer 1 sentence posts before.
Old 05-26-2022 | 03:28 PM
Bonez's Avatar
I have my headlights on auto and I never hear a chime unless key is in ignition.... There may be a sticky switch in the ignition thinking the key is still in even when its removed?
Quick Reply: Door chime keeps chiming
