Door won't open from inside
Old 11-30-2015 | 01:39 PM
kody's Avatar
Hi guys, 2009 Drivers door won't open from inside. I already had the broken door handle thing, and had a shop replace it. Worked fine for a few months, then all of a sudden door won't open. Took off the inner door panel and every things still attached, etc. I thought maybe the cable was the problem, but when I move it I can feel the lower door jamb part making noise, but door just won't open. It does from the outside no problem, and the doors lock and unlock fine, just won't open from the inside. Can you adjust the door cable, or do they wear out? Any advice would be appreciated, these driver door problems are getting old quick, thanks.
Old 11-30-2015 | 02:31 PM
Lucky's Avatar
Go here and look at post 127. This tsb should guide you to the problem.
https://www.chevyhhr.net/forums/prob...-23231/page13/
Old 11-30-2015 | 03:41 PM
X 2 on the TSB Lucky posted
sammyrye
06-04-2020 02:58 PM
TORRED1
05-17-2020 10:42 PM
SwaintaN
03-04-2018 04:22 AM
Bystrakps
08-08-2014 10:40 PM
ecl
07-31-2010 01:35 AM
Quick Reply: Door won't open from inside
