Doors rubbing against body
Old 01-25-2009, 05:07 PM
turbotim's Avatar
Both of my front doors are rubbing against the body in spots. I've had the car since the end of April and in the areas where contact is made they have rubbed all of the blue paint off. These are small areas I'll try to get pics up sometime soon.
I have had the car into the dealership and spoke with the body shop manager. He says the doors cannot be adjusted on the HHR and the only thing he can do is order new door weather stripping to see if that will push the door out a little bit more but he is doubtful. I'm waiting on the new seals.
If there is no adjustment possible on the doors is this a common issue for the HHR? Has anyone else had a door rub and had luck getting it successfully repaired?
turbotim is offline
Old 01-26-2009, 08:26 AM
galtjunk's Avatar
The drivers door on my 09 SS rub on the running board. It goes in tomorrow for adjustment and paint.
galtjunk is offline
Old 01-26-2009, 08:36 AM
ZTony8's Avatar
My driver's door hits in one spot.I'm going towait until the weather breaks to have it fixed.What's weird is that it didn't start doing it until just the last month or so.
ZTony8 is offline
Old 01-26-2009, 09:41 AM
a76marine's Avatar
Is it metal on metal or the snow buildup a lot of us here in colder climates are dealing with? The snow sounds like metal on metal and I often find myself checking to make sure that's all it is.
a76marine is offline
Old 01-26-2009, 05:13 PM
R60us's Avatar
Had my drivers side door adjusted three weeks ago at the Chev dealer (under warranty). It was rubbing and now it is all good.
R60us is offline
Old 01-27-2009, 07:36 PM
turbotim's Avatar
HHR Door Rub Pics
I was able to take pictures of my doors rubbing against the body. Have not heard back from the dealer regarding new door seals.
Pictures
turbotim is offline
Old 03-31-2009, 12:16 AM
thorn11166's Avatar
mine is rubbing on the outside... i'm not gonna go take pictures to night but its the passenger side.. on the door where it meets the fender flare... i never use the passenger door so i don't know how long its been going on but i got back from wyoming and put stuff in the passenger side and heard it scraping and checked it out... then i got pissed lol, got an appointment to get it checked out along with another list of issues at 8am wednesday... *sob sob*
thorn11166 is offline
Old 03-31-2009, 08:12 AM
MikeX's Avatar
I believe that is Bulls**t. The latch is what controls how far in the door will go, and the rubber seals are what press outward on the door to stabilize it in the closed position. I've adjusted the latch on my Toyota truck before, because it was doing the exact same thing as what I see in your picture. It did that brand new from the factory. Your door is going in too far before the latch engages. All you should have to do is loosen the latch and move it outward a tiny bit at a time until the door closes snugly and it stops hitting the body. Not rocket science.
MikeX is offline
Old 03-31-2009, 08:50 AM
birdflames's Avatar
My passanger rear door had a line of scuffed paint when i bought it. I realized when you open the pass rear door it was touching the front pass. door when all the way open. i removed the door protectors, and solved the problem. not quite the same as yours but smiliar. hope it gets fixed!
birdflames is offline
Old 03-31-2009, 10:55 PM
thorn11166's Avatar
i got to take mine in at 8am to let them look at a long list of stuff... this included
Quick Reply: Doors rubbing against body
