Electric Door Locks
Electric Door Locks
I have a 2007 HHR, and just found this website ... great!
I am having a problem with my electric door lock (driver side only). Intermittanly, it will not open with either the fob or the door switch. Sometimes I can pull the knob up while simultaneously engaging the electric switch (either the fob or the door switch). Other times I cannot budge it at all. When it does not open electronically, it will also not open by simply using the key.
Climbing into the drivers seat from the passenger side is getting old! Any suggestion on the problem and solution?
Thanks,
Joe
Thanks,
Joe
What jx3 said is referred to in post # 96 in this thread https://www.chevyhhr.net/forums/show...r+lock&page=10 but it said it is for 09's. Others, even my 08 had a rear door that had that problem
New Members: just click on the above URL and it will take you to the thread.
had same problem last wk. &found a T.S.B. regarding this problem on this forum.took it to dealer 2 days ago along with tsb and they enlarged the door lock knob hole and 45 min. later i was on my way.can;t thank forum members enough for all info on this site. also for your info they at first suggested to replace the acuator solonoid but i really didn;t want the door panel removed if not neccesary, please try tsb first. hope this helps. regards &later KEWATIN
HELLO JOE
the chev TSB#09-08-64-029 is what you are looking for. also the writer above my first post put a link in red,if you click on ,it will take you right link and scroll down till you see tsb # along with photos and you will see your problem and how to fix it. ,if not take it to your dealer. hope this helps you. regards&later KEWATIN
