electrical problem?
Old 04-30-2015 | 12:22 PM
gwbaker's Avatar
electrical problem?
A/C quit working about the same time I got fault codes for cam timing solenoids. A/C is fully charged, but compressor doesn't come on. Is there a common electrical connector for these that may be corroded? Input or a wiring diagram would be appreciated.
Old 04-30-2015 | 12:41 PM
LawDog88's Avatar
Cam solenoid codes are the only thing you are getting? If the A/C is not working, I would be inclined to think there is a code for the T-stat not working.
What Year/Trim level do you have? and how many miles?
Last edited by LawDog88; 04-30-2015 at 01:46 PM. Reason: Pardon my mistake Whopper
Old 04-30-2015 | 12:49 PM
Did you fix the solenoid problem?
Old 04-30-2015 | 12:59 PM
And what exactly were the codes you found?
Old 04-30-2015 | 01:35 PM
gwbaker's Avatar
Not yet. I will have some time this weekend to check resistance readings to see if they're within specs.
Old 04-30-2015 | 01:43 PM
[QUOTE=LawDog88;778573]Cam sensor codes QUOTE]
Solenoids! Not "sensors".
Old 04-30-2015 | 04:54 PM
Why? What are the "Pxxxx" numbers? I have a feeling somebody told you P0128 means "valve timing". That is agreeing with LawDog88 .
Many trouble codes are interrelated. One can cause many other problems.
There is a link in my sig, just click it.
Old 04-30-2015 | 05:14 PM
Stop by your local AZ and have the codes pulled
Old 04-30-2015 | 07:54 PM
FYI.
Since nobody mentioned it. Certain CEL codes will disengage the AC compressor.
In other words. The computer will shut down the compressor until those codes are fixed/cleared.
Old 05-01-2015 | 07:20 AM
FMG you mean like P0128 and P0011 and other camshaft codes?
Yes they will shut down the A/C
I know what I think is the problem but the codes will tell us what is the solution
Quick Reply: electrical problem?
