Engine block heater electrical plug
Old 01-13-2015, 12:16 PM
Marush's Avatar
The plug part of my block heater cord broke off. Can it be replaced or do I have to get a whole new block heater? 08 HHR
Marush is offline
Old 01-13-2015, 01:06 PM
the_shmoo's Avatar
No, just the replacement cord. The plug has a built in thermostat..
Hope this helps.
the_shmoo is offline
Old 01-13-2015, 04:42 PM
Marush's Avatar
block heater cord
how does it attach?
Marush is offline
Old 01-13-2015, 05:50 PM
the_shmoo's Avatar
There is a thin spring type washer (which can be turned to release) on the cord that is secured on the threads of the block heater. (It can be seen from underneath.)
Then just pull the plug off the heater.
Old 01-13-2015, 05:51 PM
Marush's Avatar
Thank You!!
Marush is offline
Old 01-13-2015, 11:58 PM
the_shmoo's Avatar
You are welcome. Hope all works out for you.
Old 01-15-2015, 05:53 PM
Marush's Avatar
Location of engine block heater 2008 HHR
Lost the cord. Got a new one but we cannot locate the heater to plug in the new cord. Any help or diagram would be appreciated. Thank you
Marush is offline
Old 01-15-2015, 06:01 PM
On the firewall side of the engine block under the exhaust manifold, Google "where is block heater on HHR" scroll down to images and there is a picture for you
Oldblue is offline
Old 01-16-2015, 12:18 AM
merged the two threads
whopper is offline
Old 01-16-2015, 08:39 AM
Marush's Avatar
Question Location of block heater
Admittedly not car smart. Googled location of block heater. Located pictures. Still dont quite understand where it is. Is it on the side of the block? Assumably we have to remove the air filter thingy... Sorry. Just trying to find to attach the cord
Marush is offline
Quick Reply: Engine block heater electrical plug
