Engine block heater electrical plug
the heater looks in the picture to bolt to the block just under the exhaust manifold, the cord plugs into the extension , you will need to remove the air filter box.
http://www.tonkinonlineparts.com/ima...191T01-002.JPG
Look at this link: https://www.chevyhhr.net/forums/how-...e-light-52828/
Installing block heater hhr, cobalt 2.4
I am having one installed thursday parts and labor $200.80 at a gm dealer. Aluminum engine block so they use a bolted on heater that attaches to the block. The heater does not go inside the water jacket. It is on passenger side on the engine side away from the radiator, remove air intake cover, then shield for exhaust. One bolt to remove or install. Has extended piece that allow for the 110 volt power to installed. Need mirror to see the spot and is tricky to install according to a mechanic on u tube. He also pointed out that heat radiates to the block and also releases heat under the exhaust shield, warming that area of the engine. Took me a hour or more to find this information earlier today.
