engine or clutch issue or both standered tran
Old 09-17-2012 | 07:43 AM
hhrlover101's Avatar
Unhappy engine or clutch issue or both standered tran
just recently i had my clutch replaced and for the last month its beeen working great. but latley when i start off the engin sounds like its bouncing around under the hood. "its like the clutch does not engage right or something is loose. this issue has never happenned befor. last night i was at a stand still starting to go up a little hill for a intersection and it sounded like the engin was bucking not the car. has any one else had this issue? if more info is needed let me know
Old 09-17-2012 | 09:03 AM
Hard to say but it sounds like you are describing clutch "chatter".
Old 09-17-2012 | 09:22 AM
foolmoon_design's Avatar
Something is loose, or cracked plates.
Old 09-17-2012 | 10:16 AM
this happends mainly when the moter has been running awhile. is there a possibility of blowing the motor if this issue gets worse?
Old 09-17-2012 | 10:39 AM
Best to take it back to where you had the clutch replaced.
Old 09-17-2012 | 11:30 AM
i am gonna do that now ill post wht it was once i figur out whts wrong
Old 09-17-2012 | 02:09 PM
the shop says i am hearing things
Old 09-17-2012 | 06:54 PM
Laco's Avatar
Are you hearing this, or feeling it. Clutch chatter is easy to feel, but typically isn't accompanied by much sound. It could also be bad engine mounts, allowing the engine to move around and rock too much.
Old 09-18-2012 | 01:55 AM
i more feel it then hear it. it its really weird but doesent happen all the time
Old 09-18-2012 | 08:48 AM
i am taking it to another shop my car is getting looked at bumper to bumper
Quick Reply: engine or clutch issue or both standered tran
