Engine cranks but will not start
The Dealewr replaced the ignition lock and complied with the recall. They also replaed thew fuel pump. Now the engine will not start. It cranks over but will not start. I also have two new keys! The part number of the ignition cyclinder kit is 23234399. Any ideas why the engine will not run?
I also checked he pin # 16 on thew OBD and there is no voltage there. I also check the fuse # 13 and it is good. Thew dealer replaced the ignition switch so I will take a look at this also ! All that was done is a new fuel pump installed. Recall on the key ( 2006 HHR) And ignition switch. The old fuel line was repaced by me! Gas flows in the line but not reahing Fuel Rail.
