Engine electric fan keeps running when I cut off A/C
Noticed Saturday coming home when I cut off my A/C bout 1/2 mile from home the engine fan kept running.
I tested this yesterday & it will be off on start up, but once I activate the A/C, in a few seconds the fan will start, as it should. But is has begun not shutting off when I shut off the A/C..
Relay going bad or ?
Itll run for a while after cutting AC off. Ive used AC during highway stretches of my commute, turn it off and put the windows down when i get into town and by the time I pull into the garage the fan is off as well, all the whuile the car never dips below 187 degrees
