engine knock???
Old 06-06-2014, 05:59 PM
blue car's Avatar
engine knock???
sounds like lifters clatter however added stp , had oil flushed and changed no difference , could it be injector noise , still getting 26 per gal help
blue car is offline
Old 06-06-2014, 06:25 PM
What engine - and what year? And how many miles on it so far?
whopper is offline
Old 06-06-2014, 06:37 PM
X2 on needing info.
Plus. Does it clatter just on start up ? only when accelerating? all the time ?
Where is the noise coming from? Front of engine? Back?
firemangeorge is offline
Old 06-06-2014, 07:50 PM
blue car's Avatar
full time knock it's front top side two sounds one sounds like lifters the other just knockinf =g sound 200,000 miles
blue car is offline
Old 06-06-2014, 08:00 PM
First thing I would do is check for oil pressure. With a gauge, not just going by the light.
Old 06-06-2014, 08:15 PM
Vaux's Avatar
Try Archoil, Archoil | The Latest Developments In Nano lubrication http://www.ebay.com/itm/Archoil-AR-S-Kit-for-Car-Truck-ATV-Treat-up-to-8-Quarts-Oil-336-Gallons-Any-Fuel-/140952452580?pt=Motors_Automotive_Tools&hash=item20d16bbde4&vxp=mtr#ht_1040wt_900
I put it in a 2010 Equinox (4 cylinder) only product that stopped detonation. Higher octane was a waste of money, other fuel additives useless. Expensive, but I did notice improvement in mpg, at current useage it would save me about $80.00 a year in gas. Eventually pays for itself. I used the fuel and oil treatment.
Vaux is offline
Old 06-06-2014, 09:22 PM
I thought I asked what year and what engine it was. :)
whopper is offline
Old 06-06-2014, 09:36 PM
blue car's Avatar
sorry its an 08 mid size engine no turbo 2.2
blue car is offline
Old 06-06-2014, 09:45 PM
Snoopy's Avatar
Archoil.....interesting product. But I doubt if it would correct an engine mechanical problem. Might be a "Band-Aid" approach, covering the underlying problem.
Excessive valve train, or engine knock (if it is) if far different than spark knock do to low octane or poorly blended gasoline, imo.
Snoopy is offline
Old 06-06-2014, 10:23 PM
blue car's Avatar
will try more oct just for drill
blue car is offline
Quick Reply: engine knock???
