engine light on, no remote control
Old 06-06-2012 | 08:24 PM
patrick31ca's Avatar
man these computers in cars are so touchy!
Old 06-06-2012 | 08:29 PM
foolmoon_design's Avatar
Welcome to the forum!
Yup engine light comes on, remote start won't work.
Also won't work with the hood open.
Old 06-06-2012 | 09:07 PM
Welcome to the site. Not touchy but can be a pita. It's just doing it's job as it's programmed to do. Find out what code it set. Fix and reset the CEL and you should be back to normal.
FWIW. Us stick shift HHR's don't even have remote starting.
Old 06-07-2012 | 11:18 AM
to the forum patrick31ca!
As stated above, once the fault that caused/is causing the CEL has been repaired, the remote will again function as designed.
If you need help in determining the cause of the CEL, have your codes pulled and post 'em up here, we'll put our heads together and try to point you in the proper direction for a quick repair.
Old 06-07-2012 | 03:02 PM
mmont50's Avatar
If you have OnStar, in your car call onstar and ask for an on demand diagnostic test, when they're done with the test ask for the code.....did it today...I had a P0013 bad exhaust acuator solenoid....good luck in your search,,,also it seems to be an easy repair if you can do it yourself...
Old 06-07-2012 | 05:11 PM
Snoopy's Avatar
So, are you asking a question, asking for help OR just making a statement ??
purple people eater
09-17-2016 01:07 PM
tessdan
11-05-2014 06:16 AM
ImNewHere
05-27-2014 11:05 PM
baldycmw
05-21-2012 07:30 PM
14Thumb
07-08-2011 07:05 PM
Quick Reply: engine light on, no remote control
