engine lite on
Old 08-23-2014 | 11:52 PM
leopardcurman's Avatar
Question engine lite on
hope this is rite place to ask question. went to parts store to have code read. they said cam sensor. they looked it up. but said they would call me with price. it is a 2009 2.2 eco motor. how many cam sensor does it have. the engine seames to have a miss at idle. I know it probly needs plugs as it has 159,000 on it and I never changed them so I will do it all at once. thanks
Old 08-24-2014 | 12:12 AM
Lucky's Avatar
Welcome to the site
We can try to help you but you need to post up the trouble code number.
We have seen part stores interpret code incorrectly before. For example there is a big difference between a cam sensor and a cam actuator.
The code will help us point you in the right direction.
Old 08-24-2014 | 12:15 AM
to the forum!
Do you have a printout from the parts store, or do you remember the exact trouble code/codes?
We live and die here by trouble codes, sometimes what "they" say is wrong, and what the actual problem is, are miles apart.
As far as the plugs are concerned, it's way overdue, and use AC Delco 41-103 Iridium spark plugs. The Ecotec engines were designed around the Delco Iridium plugs, and as others here have found out, they don't like other plug brands.
You might as well grab your owners manual and do all of the 100,000 mile services, with the possible exception of your transmission if it's an automatic. Auto transmissions that haven't ever been serviced, will occasionally respond to a service by failing in short order. There are times when the old, gunky, stale fluid is the only thing keeping the transmission functional.
(And as always, the odd psychic link with Lucky is up and running)
Old 08-24-2014 | 12:16 AM
Lucky's Avatar
Beat ya
Old 08-24-2014 | 12:21 AM
Pfffttt!
As you can no doubt tell leopardcurman, we handle things here with dignity and grace.
Old 08-24-2014 | 12:39 AM
they did not show me the code just said cam sensor. going to have code read at auto shop in town. I worked as a diesel mechanic for 3 years wile I was layed off. so fix it wont be eny problyn I hope. I work out of town and come home on weeked. this is my wife car. I have a 95 cady. lt 350 in it. I look up change cam solenoids and sensors. look like srs and trs sensors on Detroit diesel 60 ser. engine 1 bolt change. thanks all
Old 08-24-2014 | 12:54 AM
Keep us in the loop, and post up the codes when you have them re-pulled, the actual job isn't that hard to do. But I'd hate to see you wasting money on unneeded parts.
60 Series Detroits, dang good engines.
andyb
7
06-09-2015 11:58 PM
J.Lo
07-11-2014 06:43 PM
11matt77
01-05-2014 01:01 PM
dixiesHHR
08-30-2007 02:48 PM
Z-Man
Mid Central
18
11-18-2006 07:42 PM
