Engine Noise Question.....
Old 01-18-2014 | 07:07 PM
hauler's Avatar
Question Engine Noise Question.....
Hi everyone, I reeally am glad I bought an HHR! Everything has been good up till now. Problem: noise on acceleration, and pretty much all of the rest of the time. Is this serious?
Old 01-18-2014 | 07:11 PM
Gee, that is real specific!
I would take a real leap and suggest that you check the flex pipe, if you mean even not moving. If only when moving then check your hub/bearings.
Old 01-18-2014 | 07:17 PM
Welcome to the site.
"Noise on acceleration" is waaay to vague of a description. Add some more details such as what kind of noise(thumping, whining, scraping etc.) Also, where it seems to come from(engine area, exhaust, front, back etc.)
A random guess would be a busted flex pipe. Do a search for flex pipe and you'll find numerous threads about it.
Old 01-18-2014 | 07:19 PM
donbrew. I guess you and I were typing at the same time.
Old 01-18-2014 | 07:29 PM
hauler's Avatar
Cool to all with noise under the hood
My HHR sounds like an electric car. The sound came out of nowhere.
I'm afraid that it's a big rubber band and it is going to bust one day, but I
have AAA.
Old 01-18-2014 | 08:15 PM
have AAA.
Keep an eye on the thread you started recently, not 3 year dead threads.
Old 01-18-2014 | 08:47 PM
I consolidated everything into one thread.
As mentioned above, it could be a leaking flex pipe so give this thread a read by clicking the link below.....
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-repair-flex-pipe-31536/
If the noise sounds more like a bicycle chain being dragged across something metal, that could be a failing timing chain or chain tensioner. So listen carefully to the passenger side of the engine with the hood up for a buzzing/clattering sound. A failing chain, chain guides, or tensioner are potentially catastrophic failures which will destroy the engine if not caught in time.
I'd suggest having it checked professionally.
P.S. to the forum!
jawscardodger
03-04-2014 01:17 PM
trickss
07-17-2013 08:43 PM
jomack
01-26-2010 05:45 PM
HHR2006
11-11-2006 05:31 AM
Motormike
07-30-2006 12:40 PM
Quick Reply: Engine Noise Question.....
