engine noise when warm
Old 04-24-2016 | 07:52 PM
et7333's Avatar
My wifes 09 HHR 2.4,42,000 on engine,makes a odd noise after the engine runs for a few minutes.We thought it was possible the alternator,so I removed the belt and started it and same noise.Any ideas?
Old 04-24-2016 | 08:34 PM
With that vague a description, my only guess would be a cracked flex pipe.
Old 04-24-2016 | 08:47 PM
et7333's Avatar
with our stethoscope the noise sounds louder in the valve cover on the timing chain side which seems to transfer to alternator.
Old 04-24-2016 | 09:34 PM
A thump, bump, squeal, tick, knock, grinding, real loud, not loud, howling, screeching, etc. etc. ?
Honestly, without some kind of description of the noise, I'm not even going to take a guess.
Old 04-24-2016 | 09:40 PM
et7333's Avatar
it makes a whinning sound at idle and noise goes away at about 3000 rpm.Almost sounds like a convertor whine except its in the engine.
Old 04-24-2016 | 10:07 PM
Pull the valve cover , check the timing chain guides and tensioner.
Old 04-25-2016 | 02:17 PM
et7333's Avatar
took it to dealer today and called gm customer service.
Old 04-25-2016 | 02:30 PM
Let us know! Oh, another thought, the air filter box bracket
Old 04-25-2016 | 04:36 PM
Called GM customer service ???
There must be some details that the OP is leaving out. Never heard of someone taking their car in for a noise AND calling GMCS at the same time. Why would a 7 year old car deserve a call like this ?
Old 04-27-2016 | 09:08 AM
et7333's Avatar
The problem is the water pump.
Quick Reply: engine noise when warm
