engine rattle
engine rattle
So I have had a rattle at startup lately, lasts for maybe 3-4 seconds and stops. Definitely sounds like its coming from the passenger side of the engine (most likely timing chain components). I had posted a while back, a picture of the updated timing chain tensioner bolt that had been installed. As pointed out before, the tensioner doesn't look to be as young as it is. Anywho, I recently took the engine cover off to inspect the chain and see if it had actually been changed and/or if it looked to be stretched. From what I can see, it definitely looks to have been replaced. What could be causing this rattle I keep hearing? Is it possible whoever replaced the chain did ONLY the chain and not the guides? I really do not want to attack the job myself if I dont have to. Thanks!
Moved posts to a new thread where it might get some views. Asking questions in your introduction is not a good idea.
The plastic part of the upper guide looks to be new. Can you depress the chain between the sprockets with your finger? If you can discern movement with your fingers it needs to be looked into.
A few years ago we went through a long diagnoses of such a noise that turned out to be a RC Cola cap stuck in the alternator.
Need to look down the cavity, to see if the front guide is broken or the bolt has wiggled its way out, it could be the tensioner is waiting for oil pressure to build! Then it might be the guy didn’t know to engage the tensioner!
I looked into the cavity and didn't see anything out of place, but honestly I have done much more research since then and I may need to have another look now that I know more of what to look for. If I were to remove the tensioner and look at it, could I tell if it is properly working?
If you remove it it will fully extend and resetting it is a bigger pain than a new one. However, removing it to discover it has not deployed would work.
In other words: have a new one on hand if you remove it.
I ordered a new AC Delco #12608580, when it arrives I'll pull the old one out and swap them.
