Engine troubles
Engine troubles
I have a 2006 that has developed a starting problem it was fine then one day when I tried to start it I turned ignition everything went dark on dash and nothing happened when I released key dash came back to normal. I put new battery had old one tested and it was bad but it didnt help can anybody help please.
Double check the connections at the battery. The clamps on the battery are a bit weird for some people, and some people have found them loose.
Are you sure the new battery is up to snuff with a good charge (even if new)? These cars are very sensitive with low batteries, and can cause all sorts of weirdness if the battery is low.
Also check the fuses under the hood.
You don't know if anyone tried to jumpstart the car after the battery died? If you don't follow the directions the entire electrical system could get fried. Directions can be found in the Owner Manual (SEARCH "owner manuals") and most cars still have the stickers under the hood.
The new battery didn't help what? Is there power to anything, or it just won't turn over. Complete sentences help us understand.
