Esc inactive + voided warranty
shortonmoney2: Back in post #15 you said something about having a bad O2 sensor and Tmap problems.(really hard to understand with the writing)
If you have these problems, the computer may not allow the system to operate correctly. In other words,it may not let you change between the different modes because of a noted error by the computer.
I see that you said there was no codes or CEL's. If that's true, then how would you know these parts where bad?
I'm thinking that you have some trouble codes stored and maybe don't realize it.
The map sensor just needs cleaned for further lack of a oil catch can the oxygen sensor still works but it cant detect heat temps anymore and thats why the code went up, neither of those effect the operation of the esc or the traction control this is a stand alone issue with the esc and traction control plus it only lets me peak at an outstanding 8psi when it supposed to be 28lbs
