Exhaust leak
Old 05-08-2013 | 12:41 PM
solman98's Avatar
Originally Posted by donbrew
The difference between auto and standard is the before HO2 sensor is mounted on the manifold on the standard and on the pipe on the auto (at least the ones I've seen). I have no idea why they would say that the new flange would be specific to one or the other, in fact the welder has to do more work cutting and fitting to the auto pipe. I do note that there has been a flange/flex part on ebay that has the HO2 bung included on it.
Thanks for that info.
Old 05-08-2013 | 07:08 PM
jay loukakis's Avatar
I have a 2006 2lt and the flex-pipe was installed no pronlum and I have the auto trans.
Old 05-08-2013 | 08:16 PM
It was not really a problem. The welder just had to do a cut out to go around the HO2 bung. He was more pissed that I only brought him the pipe not the entire car. The one I got was from ZZP (I think), others may be different.
Actually, I was looking at Autozone the other day they have the entire pipe with the braided flex pipe now for not an outrageous price. Most after market Catalytic converters are illegal in California, for some reason.
Old 05-22-2013 | 05:50 PM
hhrbeast07's Avatar
Originally Posted by jay loukakis
I got a quote for $500.00 from a dealer plus shipping so I bought just the flex pipe and am happy with results thats why I dont buy anything from stealing dealers, the parts dept people should be wearing a gun and mask as they are robbing you every time you buy parts from the dealers.
exactly my rear passenger dome light switch broke and to replace it they want 40+ dollars for just the switch not housing and switch
Old 05-23-2013 | 03:33 PM
Here's a tip for you - when you get a quote on the price at the parts department, just ask if they can do better on the price first quoted. Often they have some flexibility, and the results may surprise you. At the very least, it can't hurt to ask.
Old 05-23-2013 | 05:05 PM
2008LT's Avatar
Defects in the exhaust flex pipe are covered under the 8 year/80k cat warranty, just FYI.
Old 06-10-2013 | 03:43 PM
Beachbum1's Avatar
leaking exhaust pipe at flex pipe
having recently read about this my 07HHR with 84000 appears to have just started leaking, or should I say that I can now hear it. I'm guessing the dealer won't touch it under warranty if it's only good to 8/80000.
My question is: Anyone living in the FL, Tampa, Bradenton, Sarasota that might have had this problem and got it repaired by buying the short flex pipe part and taking your HHr to a muffler/ welder for the repair rather than replacing the whole exhaust system ?
would appreciate hearing from you
Old 06-10-2013 | 08:30 PM
The EPA warranty varies by year, check with GM for your specific car.
HMS
07-30-2014 08:21 AM
Izzy
11-24-2013 08:23 PM
AJochum
12-18-2011 04:53 PM
calgaryhhr
10-22-2010 03:15 AM
Quick Reply: Exhaust leak
