First post...Tranny ? and RPM's
might not be the physical converter..it could just be the solenoid or wiring..possibly even programming..or the valve body. With converter lockup there will be minimal rpm change when you lift off the gas..otherwise if it drops and then shoots back up with gas applied then your not locked
