Flex joint on downpipe
Just bought another HHR for the wifey. So far have replaced busted struts and plates, end links, output seal leaking(fixed under warranty) and now the flex joint has cracked. GM turned down the repair. 2k out of emissions warranty. $900 for repair. Searched and saw some have fixed with welding in a new flex joint. Is that working out good? Called local exhaust shop and said could fix for $150 or less. I live next to Va and already got a warning ticket. They take exhaust coming in the cabin seriously. Have to keep the windows cracked open when the heat is on because its pulling fumes in. Should I go for the weld or buy the whole pipe?
It will hold up great and save you a fortune
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-repair-flex-pipe-31536/
The weld on job will last longer, maybe forever. The whole pipe can be done in your garage with jack stands an a bit of muscle 5 nuts, 2 gaskets and some knuckle salve when you disconnect the HO2 sensor wires.
Thanks for the link! We are doing this project as well. I am waiting for arrival of the same pipe pictured in the other thread. I was rear ended a third time. Exhaust leak after impact. Insurance refused to fix it. So...... Mr FixIt is doing it himself.
Well I've tried several local exhaust shops and none are willing to do the cut and repair on the exhaust. Car is sitting in driveway, because the fumes will give you a monster headache. Will try searching farther out when the weather permits. Have to keep the windows down.
Technically speaking, they are repairing a catalytic converter....I'm wondering if there might be some kind of legality issue involved depending on what state you live in.
You are spot on. They are not supposed to modify a converter. They can cut out a faulty one if there isn't a OEM replacement, which there is for the hhr, to the tune of 400 bucks. I did find 2 today, that said they have done them before, so i'm going to pay them a visit tomorrow.
