Floppy driverside sun visor.....
Old 08-09-2015, 09:48 AM
  #31
Buy one and let us know.
donbrew is offline
Old 08-12-2015, 01:51 AM
  #32
2smokey's Avatar
my visor does the same thing i about ripped it off sitting at a light one day it drove me so crazy.i got another from the junkyard that has real good flip to it but never installed it
2smokey is offline
Old 08-12-2015, 07:37 AM
  #33
33willys's Avatar
Floppy visor
Update on my fix in post #21. Visor has not flopped down once and is easy to pull down to block the sun. Total cost was under $1 (actually had the screws, washers and nuts on hand) and took about 20 minutes to do.
33willys is offline
Old 05-20-2017, 01:26 PM
  #34
mpotvin's Avatar
Just bought a 2011 HHR with floppy visor. Unless I missed something with the other posts, my fix was a small strip of duct tape wrapped around the rod-portion of the visor where the clip holds on. Seems to be working but I'll go drive on some Michigan pothole roads to double check... :)
mpotvin is offline
Old 05-20-2017, 02:57 PM
  #35
Welcome to the site, enjoy the ride!
Oldblue is offline
Old 07-23-2017, 11:39 AM
  #36
GN1220's Avatar
If you're still around would you mind posting a pic?
GN1220 is offline
Old 07-23-2017, 11:47 AM
  #37
33Willys hasn't been here since Jan 30, 2017, perhaps sent him a PM
Oldblue is offline
Old 07-23-2017, 01:19 PM
  #38
Could just read post #12 and post #21, they seem pretty lucid to me.
My binder clip solution worked for a long time. My first try was wrapping tape around the rod, that lasted a while. You just need to add friction to the joint.
donbrew is offline
Old 01-16-2021, 03:19 PM
  #39
Richard Byers's Avatar
Floppy sun visor fix
Originally Posted by Radco
I tried Viagra but the doors became HARD to open because the door hinge's got stiff! :O
I took a small cotter pin and tapped in between the rod and the case and it fix d the problem.
Richard Byers is offline
Old 09-09-2021, 12:26 PM
  #40
Cheap Guy's Avatar
There's a guy on YouTube who used a zip tie to fix his floppy sun visor. Basically instead of using tape, he used a zip tie jammed into the slot. I tried tape (didn't work) and was about to try the screw method but I gave the zip tie fix a try and it worked perfectly. You may have to cut off the head for the visor to slide back fully on the rod so it will clip back onto the retaining bracket but even without that, there's no flop at all.
Cheap Guy is offline
Minibikeman
12-20-2020 08:30 PM
hillbilly4u
04-16-2020 09:17 PM
kustom
12-31-2017 01:08 PM
larryv
07-14-2014 06:31 AM
HHR_style
12-25-2010 04:19 PM
Quick Reply: Floppy driverside sun visor.....
