Fluttering Locks - Slips into Neutral
Old 02-15-2014 | 01:07 PM
collinsrhp's Avatar
While driving my car slipped into neutral and my locks started locking and unlocking rapidly (fluttering) - all doors. Checked battery. Battery is good. Drove the next day. It drove fine for about 30 minutes. Then it started happening again. After car sat for several days battery was still good but weaker. Sat a couple more days, now battery is dead.
Any help would be greatly appreciated.
Old 02-15-2014 | 01:17 PM
to the forum!
How did you check the battery?
Did you just check the voltage with a VOM, or did you have it load tested?
It sounds like you have/had a failing battery or charging system issue, low voltage will cause an HHR to go into "nervous breakdown" mode, and all sorts of odd behavior will ensue.
Your first step would be to charge the battery and then have it load tested if you haven't already.
Old 02-15-2014 | 01:19 PM
Welcome to the site. I think the battery is bad but you said it was checked.
I say that because many have had their car do weird electrical things, including my panel. New battery no more weird stuff.
How old is the battery ?
Old 02-15-2014 | 02:59 PM
Wait a minute!
The transmission spontaneously shifted itself into neutral? I don't know how that is possible.
Battery dead after sitting a few days indicates a worn out fellow.
Old 02-15-2014 | 03:02 PM
You didn't state it in the 1st post but your profile says you have a 2006. Is this correct? If so, and it's the original battery, then I would surely suspect an 8 year old battery could be the problem.
P.S. Welcome to the site.
Old 02-15-2014 | 08:05 PM
Hey collinsrhp,
Welcome to the forum! You've come to the right place to share your passion for the HHR! I can understand why you would be concerned over these symptoms that your vehicle is displaying. Is this something you were planning on tackling yourself, or were you planning on consulting with your local dealership? If I can be of any assistance feel free to reach out via PM.
Take Care!
Jonathan A.
Chevrolet Customer Care
Old 12-24-2017 | 10:21 AM
migjesse20's Avatar
did a new battery fix your problem?
Old 12-24-2017 | 10:26 AM
You could go back to AZ and have it load tested.
Old 12-24-2017 | 10:30 AM
They were a 1 and done poster, from nearly 4 years ago. I've got you in your own thread now.
Old 12-24-2017 | 10:33 AM
migjesse20's Avatar
ok thanks I'm still figuring how to work the site,im going to auto zone right now to have it rechecked.
Quick Reply: Fluttering Locks - Slips into Neutral
