FOB programming
The FOB has become a dealer programming item with the HHR and you can't do it like on some of the other cars. I have a 02 Impala also and was able to reprogram an extra fob myself, it was spelled out step by step in the owner's manual. Now you can program a KEY after it is cut and that info is in the manual.
No, the programming mates the fob id number in the BCM. Fob has to be programmed with the vehicle.
Even when programming a replacment FOB, is it correct that you will also have to reprogram your original Fob?
Last edited by GRUMPEE; 02-11-2009 at 02:36 PM. Reason: rewrote - due to bad corrupted memory
My understanding from reading this Forum:
The FOBs can be programmed by a Dealer or a properly equipped Locksmith. Most on this forum say the Locksmith is less expensive - I haven’t checked yet. All FOBs have to be present when adding any FOBs as the programming of additional FOBs erases the previous FOB programming entries. The number of FOBs the vehicle can be programmed for is ONLY four(4).
Keys, however can number up to ten(10) per vehicle. Those new keys can easily be programmed yourself by following the instructions in the Owners Manual or by other posts in this Forum.
This is all I know!
This is all I know!
