Fog Light Harness
Fog Light Harness
Does anyone know of a wire harness change from 06 to 07. I am looking for the Fog light wires in the front clip, but they do not seem to exist.
The dealer shows them in the wiring diagram, but they are definately not on my early 07M. Dealer thinks there may have been some change to the harness.
Thanks
Thanks
I have an LT with No Lights. The harness is supposed to be there but it is not. When the dealer searches by vin number for parts it comes up with the new LT harness, but the part number does not match what is actually in the car.
Fog Lamp factory harness vs. replacement.
I had this same problem when I was putting fog lamps in an 07 LT. after some research the dealer parts manager an myself found that the replacement harness has all options on it which will have fog lamp wirring but the factory installed harness will not have the fog lamp conectors if the car did not come with fog lamps. I guess they save money that way?
I did not buy the harness I made up my own and added it the the factory harnss. you can buy the connectors for the fog lamps a local parts store and an asortment pack of spade connectors will give you the one you need at the under hood fuse box (PDC) I beleve they are small like speaker connectors.there is a nother thread in here that will give you the pin number and diagrams.
