Frequent Headlight Failure
Old 01-19-2009 | 01:16 PM
hhrbama's Avatar
I got my HHR used in mid year 2007. I put Sylvaina Silver Star headlamps in it fairly soon. So far I have had three bulb failures. In December 2008 I had the third fail and additionally had a foglamp (stock bulb) fail both on the driver's side. Has anyone else had multiple headlamp failures? I made sure the bulbs were actually burned out and it wasn't fusebox related. I used care not to touch the glass when installing.
I have had Silver Stars in other vehicles and never had this problem. Anyone who has replaced a bulb in the HHR knows what a PITA it is to do.
Old 01-19-2009 | 03:02 PM
pitbull76's Avatar
Are you sure that there isn't a small crack or something in the headlight enclosure? If the bulbs get wet, they will burn out.
Old 01-19-2009 | 03:06 PM
masterchief1112's Avatar
i put silverstars in my truck and they had a tendance to burn out. no silverstars in the hhr yet tho.
Old 01-19-2009 | 03:29 PM
We had the same problems when we put them in some of other cars so we haven't tried them since.
Old 01-19-2009 | 06:33 PM
hhrbama's Avatar
There are no cracks or leaks in the housing. The lenses are bright and clear and there has never been any moisture in them.
Old 01-19-2009 | 11:38 PM
Snoopy's Avatar
Only 3 things I can think of.......
Poor quality control on the item
Excess heat build up which ultimately causes premature failure
A SMALL "short", which yields with certain movement/turns/potholes, etc. of the vehicle
Old 01-20-2009 | 08:43 AM
hhrbama's Avatar
Hi Snoopy,
When I replaced the left headlamp, I got one notch above stock and one below the Silver Star. I am hoping to increase the life. I guess all I can do is drive it and see.
Old 01-20-2009 | 09:28 AM
DLVRNIT's Avatar
Originally Posted by Snoopy
Poor Quality Control on the Item ?
^^ X2 ^^ We recommend PIAA's ! Very Pricey but have "NEVER" Failed Us !
Old 01-20-2009 | 09:32 AM
Goose's Avatar
I think I have have replaced the Silverstars in my HHR twice...after this last time I just went back to the Xtra Vision which sounds this is what you have done. So far they have out lived the Silverstars at a much less of a cost. I do keep the Silverstars in the fogs though. The SS were brighter and looked better but not at the cost vs life expectancy. I know some folks here have has better luck but seems like they are in the minority
Goose
Old 01-20-2009 | 09:35 AM
Goose's Avatar
Could also be the SS in this type of bulb which is some weird ass type that almost nobody else uses (9008 or also called H13 I think) just can't cut it.
Goose
Quick Reply: Frequent Headlight Failure
