Front Bumper Corner lights
Old 10-28-2010 | 10:18 AM
Kelevanwinkle's Avatar
One light went out behind the amber lens, and I have yet to have the time to pull away the wheel well to see what kind of light is used. Could not find the answer in the search feature. Does anybody know what light I need? Thanks!!
P.S.- Soon I will be posting my painted headlights hopefully, pending I can get my paint person to hurry up.
Old 10-28-2010 | 10:29 AM
Ratracer's Avatar
It's a 194 lamp.
Old 10-28-2010 | 10:33 AM
Just like the rear bumper light bulbs?
Old 10-28-2010 | 10:34 AM
solman98's Avatar
Yes
Is it the same for the back, a 194?
Manual doesn't list the side markers for some reason and I need to replace one of the back ones.......
Edit: answer came while I was asking....
Old 10-28-2010 | 10:37 AM
Ratracer's Avatar
Lamp Replacement Guide Auto Lamp Replacement Guide - Results
Print out the list and find them at your nearest retailer.
Certain bulbs are available for sale at the SYLVANIA Online Store. New bulbs will be online for purchase in the coming weeks.
Stay informed about new products from SYLVANIA. Sign up with one of our newsletters and let us help you with your needs.
When two or more lamps are listed for the same application, remove the lamp and check the numerical designation.
2008 CHEVROLET HHR
High & low beam headlamp
H13 (9008)
H13ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H13XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
Parking light
3157
3157ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3157LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
3157
Rear turn signal
3057
3057ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3057LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
3057
Stop light
3057
High mount stop light
921
921ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
921LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Fog/Driving light
9140
H11
H11SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
H11ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H11XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
License plate
168
168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
921
Front sidemarker
194
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Rear sidemarker
194
Glove box
194
Map light
2825
2825LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Dome light
562
562LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Trunk/Cargo area
PC168
Old 10-28-2010 | 10:41 AM
VERY cool, thanks Ratracer!
Old 10-28-2010 | 10:45 AM
Ratracer
Old 10-28-2010 | 11:30 AM
Took about 10 minutes to do it. Easy.
Old 10-28-2010 | 08:39 PM
BlackknighT's Avatar
The 2009 Manual only states headlights & front turn signals. Stupid...
