front end clunk
front end clunk
I have the seems to be common front end clunking on the the suspension. Nothing appears to be loose. I can grab the tie rods and struts and axle and yank and push and nothing jumps around or makes noise. Seems to happen on tiny bumps and quick bumps but if the suspension really moves, no noise. Seems to be fine. I am guessing it is the intermediate steering shaft I have heard about. It needs to be lubed apparently. I have no warranty so unless dealers do this for free, I would rather do it myself. Does anyone have a diagram of this part and how to remove it along with the type of lube required?
clunk
My 08 hhr had a clunkety sound when i went over railroad tracks or hit a hole just rite. Took it to the dealer and after they checked it out, they said it was a part in the steering sector. They ordered the part and installed it and that fixed it. Dont know if it was something else or not as long as it was fixed, and it was under warranty.
It is possible the road with the help of the heavy vehicle does a lot better job "yanking" than you can do. I've never found that I am strong enough to move much on a vehicle unless the parts are very badly worn.
Just a note, when checking the sway bar links, you must have the weight of the vehicle on the wheels. I had the same problem with mine, had to change both links. I still have another clunking noise that the garage can't find now though. The mechanic says it sounds like a table bushing but all bushings seem nice and tight. I didn't know about the steering bit though. I'll have to check that out next.
