Front end clunky noise
Old 02-08-2013 | 11:09 PM
chefan's Avatar
love my hhr..just gotta fix the clunk when goin over bumps.mechanics told me nothin wrong..so why the clunk?whats a good place to start?help
Old 02-09-2013 | 05:09 AM
B.Diggity's Avatar
Possibly strut/shock, or maybe a spring not seated correctly. Whats the sound, sound like?
Old 02-09-2013 | 09:06 AM
Jimbo_HHR's Avatar
Possibly also the front sway bar links.. seems a common problem with the HHR.
Here is the part number.. though you should verify.
MOOG Greasable sway bar links part no. K750012
JM
Old 02-09-2013 | 09:22 AM
stelerz's Avatar
Still got it
I had a clunk. Changed the tie rod ends, and replaced both struts. I had one that had a broken seal, so I did both. I have some slack on the sway bar grommets that bolt to the frame but, the shop told me you have to have a little slack, others tell their should be no slack. Who's right. with all the work still have a little clunk. Good luck if you fix it post it plz...........
Old 02-09-2013 | 10:12 AM
VinceP's Avatar
Any of the above mentioned items could be the problem. I replaced everything mentioned but my clunk did not go completely away until I replaced the sway bar bushings.
Good luck.
Old 02-09-2013 | 12:25 PM
chefan's Avatar
swaybar
the clunk comes from where your feet are...about where the sway bar is.found some hotchkiss pieces that im gonna try(s.b bushings,links)thanx for your help guys
Old 02-09-2013 | 12:39 PM
A arm bushings(lower control arm) are another part that is known to wear out and cause a front end noise.
Old 02-09-2013 | 02:09 PM
DaGrinch's Avatar
A set of these - http://www.energysuspensionparts.com...sp?prod=9.5161
and a set of Moog K750012 (or whatever length your end links are) go a LONG way to get rid of the clunking. Had the same problem with my 2008 HHR, those two fixes made a HUGE improvement.
Old 02-09-2013 | 02:30 PM
Laco's Avatar
My 2007 has a lot of the 'normal' so to speak front end clunks. Interestingly we have had quite a bit of rain, so its been really wet, and the front end clunks seem to have dissapeared. Now I would expect them to return after everthing really drys out, but that would seen to indicate maybe a rubber lube issue or??????
Old 02-11-2013 | 11:12 PM
chefan's Avatar
had er in for tires the other day,mechs said there was nothing wrong...sway bar bushings looked dry,so they sprayed them..clunk got better.so gonna start there.wish me luck n thanx for ur help guys!!!:)
Quick Reply: Front end clunky noise
