Front end noise in 2008 HHR LT 2.2l
Old 01-13-2016 | 02:53 PM
Chrisl1059's Avatar
Hey everyone! New to the forums here!
I took my mothers car to do the lower control arm bushing and noticed quite the howl when I was driving it. It has about 135,000 miles on it. Of course I immediately thought wheel bearing, as that is what it sounds very similar to. As I took the car apart I checked them and they are actually tight. But what happens is I spin the wheels and the noise is coming from the transmission/diff. Here's the kicker. I jack the front end up, spin the wheel in neutral and it makes the noise, only if I spin the fire forward, not reverse. If I put it in park, it pops, I assume the park pin going in, then it doesn't make the noise anymore. Put it back in neutral, noise again. I have a video on YouTube so you can hear it. The reason I ask here is to see if this is some common issue that maybe someone's run into before. Thank you everyone!
Old 01-13-2016 | 03:41 PM
Welcome to the site!
The hub bearing might be tight but still noisy, it could be an output bearing where the drive axle hoes into the trans.
Old 01-13-2016 | 03:46 PM
Chrisl1059's Avatar
What's getting me is when I spin the wheel when it's in park, and as soon as it pops, the noise stops, did you see in video?
Old 01-13-2016 | 05:44 PM
Brake pad wear indicator?
Old 01-13-2016 | 05:57 PM
No I couldn't open the link to your video
Old 01-13-2016 | 06:17 PM
Chrisl1059's Avatar
I don't know why it didn't link correctly, if you copy and paste it into the browser it'll go to it
Old 01-13-2016 | 06:29 PM
They do make a noise when you jack the wheels up and use the engine to turn the wheels. That is the inner slip joint over extending from hanging down too far.
Old 01-13-2016 | 06:40 PM
Chrisl1059's Avatar
I've never heard a car or truck with cv axles make that noise jacked up, and why does it stop once it's in park?
Old 01-13-2016 | 07:48 PM
Mine make the same noise jacked up on one side could be the spider gears in the transaxle turning , they won't turn in park.
Old 01-13-2016 | 08:06 PM
Chrisl1059's Avatar
I'll have to take a closer look in the morning. I don't want to be overthinking something stupid. I'd love for it to be a wheel bearing. 1/2 hour job in these things.
Quick Reply: Front end noise in 2008 HHR LT 2.2l
