Front end shudder
Old 03-19-2010 | 01:48 PM
Waynejwj's Avatar
Question Front end shudder
I have a 2009 HHR SS Automatic with 12,000 miles. I have been noticing a slight front end shudder when I take off especially if I am turning. This condition is getting worse. If I take off fairly easy as I usually do it is barley noticable. If I take off just a little harder than normal the car will shudder up through the steering wheel up to about 30 miles an hour and then smooth out. The harder I take off the more pronounced the shudder seems. This is through first and second gear. I have tried all transmission variables and the result is the same. anybody had this experience.
Thanks
Wayne
Old 03-19-2010 | 02:06 PM
pitbull76's Avatar
Nope. You're under warranty so just take it in.
hyperv6's Avatar
Just take it to the dealer. It could be a CV joint, tranny or a number of things.
Old 03-19-2010 | 02:28 PM
ChevyMgr's Avatar
Sounds like an axle or cv joint to me too.
Old 03-19-2010 | 04:10 PM
Snoopy's Avatar
I agree with the above.
You're indicating the same symptoms that my GD experienced in her Impala. Just replaced drivers side CV joint. Took care of the problem.
But sometimes I am wrong, also.
Maxxdd
11
04-12-2015 06:38 PM
Doctuh
10-27-2010 03:29 AM
Brucet
07-13-2008 10:10 PM
jerij
07-13-2006 10:18 PM
Quick Reply: Front end shudder
