front speakers sometimes work-sometimes don't
Welcome to the site
Normally the speakers them selfs fail. When I'm testing radio outputs I use a 12 volt test light.
With a test light hooked up to the two wires going to the unplugged speaker and the radio volume turned all the way up you will see the test light bulb flicker with the beat of the music if the out put and wiring from the radio is working properly
Hi cstough,
Welcome to the forum! I’m sorry to hear that you have this problem with the speakers in your HHR. Please feel free to send us a private message with your full contact information, VIN, current mileage, and preferred dealership so that I can look further into this for you. I look forward to hear from you soon!
Kristen A.
Chevrolet Customer Care
Kristen A.
I had a similar problem with my 08, except that none of mine worked besides the tweeters on the a pillar. Every once in a blue ill hit a bump and will all come on. The audio store I went to told me this is a common problem where rain water will get down inbetween the window and window seal and short out the speakers. I got all for of mine replaced and never had a problem since.
my driver door speaker won't work when it rains, works when it dries out. Waiting for more than one day of dry weather (not too many here in the Pacific NW) to pull the door panel and fix it. The "leaving the key in the ignition" dinger doesn't work either.
