front window
front window
does any one know the length of the top part of the front window? every time i mesur i cant get it right. the reason i need to kknow is i am going to buy a undercover visor light for my car. car is a 2008hhr ls
Agree with Whopper.....with the addition of........
Passenger lower corner has the spec numbers for safety and I believe GM's. Don't know if you can decipher them though. You could use them for comparison.
I'm guessing the top and bottom width of the windshield will probably be 2 different measurements....do to the curve of the glass. And that raises the question, measured straight across, at a specific point or following the curve at a specific point.
We would like to help, but we need PROPER info to do that!
So what are you SPECIFICALLY looking for?
As suggested, you're probably better with measuring the glass yourself. A cheap tape measure is something like $1.00-$3.00.
