Fuel door popper
Mine still works fine, but the rubber boot has started coming off..... I can't figure out how to get it back in place....... The more I muck with it the worse it gets.
Sorry for the subtle thread jack, but it is related.
20912532 is the service part number for all years of the HHR.There's a note in the catalog that says to seal all the voids in the plunger housing with flexible sealer prior to installation of the spring.
Part numbers can change for various reasons,most usually because of either a spec change in the part or a change of vendor.The later,updated part becomes the service part for several model years unless there was a radical redesign of the part to where the new part wouldn't work without major modification to the vehicle.
