Fuel filter??
Thank you.Couldn't find one.Are there any other eccentricities to the 2.4 that should be maintenanced??It just runs perfectly,starts great,and I did a K&N air filter and it seems to be getting stronger.
For my 2011, I have a drop in K&N air filter, I wash it with the K&N soap, then let it air dry, then I mist the air filter oil , just 2 or 3 sprays, not directly into the filter, just over it, on the side away from the throttle body only. I’ve never had the oil problems.
I do know that some filters came from the factory soaked in oil, I suggest washing those out and spritzing the air filter oil as I described
