Fuel Line
I did on the 2011, in October
https://www.chevyhhr.net/forums/how-...follies-62310/
this is the kit , I used for your 2007 HHR
https://rover.ebay.com/rover/0/0/0?m...2F182759213082
As the directions show blow the fitting clear with compressed air if you have it and a squirt of WD 40 to lube it oring , then you can separate the bundy fitting, For that you squeeze the D shaped fitting gentle with a pair or pliers and gently pull and twist the metal line out.
Be Careful here double check the new metal line to ensure there is no burr which will destroy the oring!
Grizzly old man
Maintenance and Upkeep
28
11-13-2015 12:16 AM
