gallons of water in my HHR
Old 11-13-2011 | 08:50 PM
  #51
Originally Posted by RetiredLE
Just saw this thread and thought I would add something. A friend of ours has a 2007 base model and discovered her drivers side seat belt was soaking wet. Turns out it was the front attach screw on the luggage rack. Once that was sealed, the water problem was solved.
Do you know if that roof rack was added after the fact, such as a dealer install, or did the factory miss that?
EDIT: I just saw you said "base model"..... that was added after the fact.
Old 11-14-2011 | 07:56 AM
  #52
Lee3333's Avatar
I have the same problem especially with rear seat belts. I removed my factory installed luggage rack, and have not gotten around to properly filling the holes. I applied gasket sealer around the bolts and re-installed them. Now I guess that is not enough, since I have the water problem. (I also removed my factory rear spoiler, and have to fill those holes in as well.)
My reason for removing that stuff-the luggage rack was never used, makes washing the car a bit harder, and decreases gas mileage. And in my opinion, the rear spoiler destroys the clean look of the back of the car. I love the retro rounded edge on the roof.
Old 11-15-2011 | 03:32 PM
  #53
Black C5's Avatar
Left Front Sunroof Drain
Still looking for the routing of the sunroof drain.
Anyone have the same problem?
Old 03-04-2015 | 08:50 PM
  #54
hammerheadHHR's Avatar
I believe I have the same problem. 2006 LT HHR w/ sunroof. I am looking for service info on the drain tube.
Old 03-05-2015 | 01:06 AM
  #55
member found the thread https://www.chevyhhr.net/forums/prob...f-drain-37865/ which had the answer to his question.
Old 03-09-2015 | 06:51 AM
  #56
Lee3333's Avatar
For the front, there are 2 tubes that run down the front pillar and exit by the door hinge. Both sides of mine were completely clogged. We tried blowing air through the sunroof ports, but they were too plugged up, so we popped them out and cleaned them. I am sure there are rear drains (for when the car is parked on a hill) but havent found them yet.
By the way, my entire sunroof seems to be loose. The glass rattles around when I am driving on the highway, and when I press on it from inside the car it moves up a little. Have to investigate more once the weather gets nicer.
Old 03-09-2015 | 06:56 AM
  #57
Lee3333. Read whoppers post #55 above your's. There is a link to the thread with a picture that shows where all 4 drains are located.
Old 03-09-2015 | 10:00 AM
  #58
Lee3333's Avatar
I will Thanks
Old 06-17-2022 | 03:19 PM
  #59
Tracy C's Avatar
Ms
Originally Posted by tooter1
If anyone needs a copy of the TSB on this subject, PM me with an email address and I'll send it to you.
please May I get a copy
Old 06-17-2022 | 08:05 PM
  #60
Since last post here was on 03-09-2015, I wouldn't hold yer breath for a reply..
Quick Reply: gallons of water in my HHR
