Gas overflows at station...
Old 06-24-2012, 09:42 PM
chadlogan112's Avatar
Everytime I fill up my fuel tank at the gas station, its overflows all over, each and every time. Does anyone know what's wrong with my her? Thanks!
chadlogan112 is offline
Old 06-24-2012, 10:12 PM
Same station?
firemangeorge is offline
Old 06-24-2012, 10:51 PM
Premiere07's Avatar
^ could be the pumps not your car
Premiere07 is offline
Old 06-24-2012, 11:11 PM
No, multiple stations sadly. It's embaressing each fill up
Old 06-25-2012, 12:08 AM
Are you letting the pump click off by itself, or are you "squeezing" a couple more clicks into the tank?
If its overflowing when the pump shuts off automatically, you may have a restriction in your filler neck.
If you're "squeezing" in a few more drops and its overflowing, just let the pump shut off at the first click, overfilling can do some serious damage to the EVAP system and cost you some dough to rectify.
843de is offline
Old 06-25-2012, 04:58 AM
bigjacksauto's Avatar
X2
bigjacksauto is offline
Old 06-25-2012, 09:58 AM
jerry455's Avatar
I have that happen at the station I use but it is only at one pump. The other pumps at that station are fine it is just that one pump.
jerry455 is offline
Old 06-25-2012, 09:59 AM
SpaceCowboy's Avatar
its overflowing to the canister...when it clicks off...its full
SpaceCowboy is offline
Old 06-28-2012, 08:34 PM
When filling, it clicks once, then "burps" gas all over the vehicle. This isn't my first rodeo.
Old 06-28-2012, 09:54 PM
OK, one click and them "burping" sounds like a restriction in the filler neck, I'd start checking there.
Did this problem just start recently, or has it been a long term thing?
You could have a "special present" in your filler from the neighborhood kids, or just some random person being a snot if you're HHR is parked outside overnight.
843de is offline
Quick Reply: Gas overflows at station...
