gas pedal\regime needs adjustment??
Old 10-12-2007 | 09:16 AM
DreamHHR's Avatar
Allright, go check this link (as well as the links to threads posted in the second post):
http://www.elantraclub.com/forum/ind...opic=17498&hl=
This is common on newer cars. There is variability, so some flare up a bit more than others. Someone there has found a way to defeat (fix) it, but I'd be hesitant to do that on a car with a brand new warranty.
TPS = Throttle Position Sensor. 2 out of 3
Yves
Old 10-12-2007 | 09:12 PM
mithril's Avatar
I couldn't have described it better ;-)
Will check with the dealer when I go in for an oil change.
Btw Mithril, are you driving a 2008 model also??
Anybody else having this prblm with a 2007 or 2006??
Oooops!..... I knew I forgot something! I have a 2006 2LT with the 2.4.
Old 10-12-2007 | 09:19 PM
R CA HHR's Avatar
I have the same or similiar problem with the 04 cavi we have. From time to time when slowing down like to pull into the drive way you'll let off the gas and then push in the clutch and the damn engine will rev to around 2,000 and stay there until you let the clutch out or stomp on the gas pedal a few times. I just figured it was a crappy cheap car and have been dealin' with it.
Old 10-13-2007 | 01:07 AM
Black Rose's Avatar
My 1989 Cavalier RS did the same thing (rev go up when clutch pushed in). It had the 2.8L V6 with MPFI.
Wrenchbender Ret
03-21-2011 01:29 AM
Lost Newfie
11
12-24-2010 01:15 AM
Quincy
08-22-2009 07:26 AM
Jeff®
06-08-2008 08:01 AM
bugflipper
10-07-2007 04:15 AM
Quick Reply: gas pedal\regime needs adjustment??
