Guys what is this part
Old 11-25-2012 | 07:21 PM
blue car's Avatar
sorry no pic but here goes . as you face the engine on the lower right side lives a canister that holds oil of some sort.. it is a top loader and the top is plastic with 1 1/4 nut on the top ( part of the plastic top) this is an 08. thanks in advance
Old 11-25-2012 | 07:24 PM
VinceP's Avatar
Sonds like the oil filter housing. Can't say for sure without a pic. Black plastic, right?
Old 11-25-2012 | 07:26 PM
badassbowtie's Avatar
^X2....only visible nut that big under the hood.
Old 11-25-2012 | 08:06 PM
Happened to have this picture in my gallery. It shows the socket set up that I use. Is this what we're talking about? If so, that's the oil filter cap.
Old 11-25-2012 | 10:36 PM
blue car's Avatar
thanks much , talk about feeling dumb, guess i'm just an olg that is use to those things being on the botton end ... thanks again... hey nice clean motor
Old 11-25-2012 | 11:31 PM
Under that 32mm black cap is the oil filter, it will come out with the cap.
Like this (see pic), & you just gently pull the filter straight off, & add a new filter, it just snaps into the cap.
I always wipe the O-rings with oil to prevent chaffing during install..
& wind back in BY HAND, then when fully seated give it a snug down (18 ft lbs) with socket/extension & rachet.
You can get the 32mm "shorty socket" at the auto parts or online.
The 1-1/4" I think may have clearance on the 2.2, but not the 2.4 engines.
Old 11-26-2012 | 08:40 AM
solman98's Avatar
They are identical between the 2.2 and 2.4. What fits one, will fit the other.
Old 11-26-2012 | 10:29 AM
solman- a standard 1-1/4" socket does NOT fit the 2.4, that I know. Gotta be a 'shorty'..
& some 2.2 guys have swapped intake for the bigger 2.4 intake manifold.
Old 11-26-2012 | 10:35 AM
Fwiw. Ain't much room on my 2.0 either, but my socket was an old one in my toolbox. Didn't have to buy a special one.
Old 11-26-2012 | 11:16 AM
solman98's Avatar
Are you saying a 1 1/4 doesn't fit the cap, or is too long? Cause both take the same cap. If the socket is too long, it won't fit period. Mine fits a 2.4 cause I've done it, but I use a 32mm, since it's supposed to be a metric and not an SAE (even though a 1 1/4 fits). It fit no tighter than the fitment on my 2.2.
Quick Reply: Guys what is this part
