half shaft removal
Old 01-27-2012 | 03:57 PM
haze's Avatar
half shaft removal
I'm trying to remove the right half shaft, any suggestions on how to remove it from the transmision without having to get a fancy tool that the manual suggest to use?
Old 01-27-2012 | 06:28 PM
SS Panel's Avatar
there's Lots of information on youtube
http://www.youtube.com/watch?v=6xb7xil4PAw
Old 01-27-2012 | 10:06 PM
Mine is a 2008 automatic, I just put a short prybar in there and gave it a sharp rap, you do not need the slide hammer, or for that matter the seal guides (for installation). The real problem was getting the "stub shaft" off so that it could be reused, you need a "bearing splitter" and a small hammer to pop it off. The bearing splitter is for loan at Advance/Zone/Pep,....but needs to be ordered, it is basically a double U clamp that goes over the splines of the shaft, but not over the stub. I was incredibly lucky in that there is a small transmission shop in my neighborhood and the owner was working on his Harley on the holiday weekend that I found I needed a "special" tool!
HHRACER
06-16-2018 09:33 AM
DrLoch
Drivetrain (Excluding Engine)
01-13-2015 02:38 PM
Lilbit
11-22-2014 12:54 PM
1highmiler
02-25-2013 06:45 PM
Zagohhr
07-29-2011 12:59 PM
