Hard time filling gas tank/ code p0446
06 2.2 ltr LT
CEL is not on....having a hard time pumping gas into the tank.
Code seems to trip randomly, have done some reading on the site and checked voltages to
The purge valve and solenoid and look to be within specs, blew out the charcoal canister and lines. So far with all the problems I have read about and fixes I have tried nothing has worked. Any further help would be appreciated......Thx
https://www.obd-codes.com/p0446
It means that the purge valve is faulty or the vent is clogged.
On an '06 you will need the pigtail adapter, many times it is included in the box.
https://www.chevyhhr.net/forums/how-...acement-44780/
Dorman , Airtex/Wells and Standard have a purge valve it comes with the pigtail
2006 CHEVROLET HHR 2.2L L4 Vapor Canister Vent Valve / Solenoid | RockAuto
If the vent valve is stuck closed the air has no where to go when the gas goes in. Like filling a soda bottle with a 5/8 hose.
It is vent system PERFORMANCE. A few years ago, I think it was Honda, had to redesign the filler tube because some breed of spider loves gasoline vapor. They clogged the system causing p0446.
