View Poll Results: How many times has your HHR been in the shop for bad rotors?
1x
56
22.40%
2x
35
14.00%
3x
17
6.80%
4x or more
2.00%
I gave up and bought aftermarket rotors
35
14.00%
I've never had a problem with my HHR's rotors
109
43.60%
Multiple Choice Poll. Voters: 250. You may not vote on this poll
Have you had rotor issues? POLL
If your HHR has under 50k miles on it, take the poll...
I would consider any car with 50k or more miles to have normal brake-wear problems, so if your has more, don't take the poll.
If you have never had any problem, there is a choice for that.
If you have had problems and gave up and bought aftermarket rotors, you can select more than one answer.
I currently have 39000 miles on it now. The only time that I had any problems with the rotors is when coming down off the Blue Ridge Parkway and had to slow down frequently due to a slow driver. I felt the rotors start to pulsate but quickly recovered when back on level ground. I feel I've been lucky so far and will go to slotted and drilled rotors at the first sign of repeated trouble.
