Hazard Button/Switch
Old 05-30-2012 | 09:04 AM
drummerboy0088's Avatar
I just noticed the Hazard button/switch in my dash is acting a little funny. It will either illuminate all the time, when the hazards are turned on (then turn off when the hazards are turned off), or when the hazards are turned off (then turn on when the hazards are turned off). The button also flickers from time to time randomly.
on a side note, I did just install steering wheel radio controls, could that be causing the issue? I have a 09 1LT.
Old 05-30-2012 | 09:49 AM
foolmoon_design's Avatar
Loose wire, does it flicker over bumps, or when radio is cranked up?
Old 05-30-2012 | 10:54 AM
Not that I've noticed. If I tap the waterfall around the switch, it flickers. I'll have to take the waterfall off and check the wiring, I just wanted to ask in case it was a bigger issue.
Sundance
02-25-2014 10:11 PM
Yonash
04-27-2011 12:36 AM
Cajun
06-12-2008 11:32 AM
