Head light problem
Old 11-20-2014, 10:03 PM
bsstan's Avatar
Head light problem
When I unlock my car (2008), my lights both burn. But, when I start it, my right side light goes out. Where do I start, any suggestions?
bsstan is offline
Old 11-20-2014, 10:12 PM
Right side bulb has a burned out filament. Replace the bulb.
(if you turn on the hi beams, I bet that both will work )
firemangeorge is offline
Old 11-20-2014, 10:15 PM
bsstan's Avatar
I'll try that tomorrow. I hope it works. It just fooled me when the light comes on when I unlock it, but is out when I start the motor. Thanks!
bsstan is offline
Old 11-20-2014, 11:54 PM
x2 what FMG said
Basic headlight diagnostics: whenever having problems with a single headlight the first step is to check and replace the offending bulb.
whopper is offline
Old 11-21-2014, 12:23 AM
geg
geg's Avatar
Many believe - if one bulb burns out, replace the bulbs in both headlights. Because the new bulb is less worn, and it kills the old lamp. A couple of times I've had it, since the time I do so always. Replacing bulbs on HHR - not the easiest thing, why go back to it twice.
geg is offline
Old 11-21-2014, 06:15 AM
LawDog88's Avatar
Exactly.
LawDog88 is offline
Old 11-21-2014, 08:29 PM
hhr06NJ's Avatar
when you arm / disarm or unlock, the HIGH beam lites up, not the low beam.
hhr06NJ is offline
Old 11-21-2014, 10:25 PM
LawDog88's Avatar
am I remembering correctly, that although it's the high beam, it's not at full brightness?
LawDog88 is offline
Old 11-22-2014, 01:20 AM
bsstan's Avatar
That explains a lot!
bsstan is offline
Old 11-22-2014, 01:39 AM
hurst2001's Avatar
Hope you got small hands
hurst2001 is offline
Quick Reply: Head light problem
