Headlights go on when put in gear?
I'm with you Theresa. I think the "bright" ambers are much more visible than the headlamps in the daylight. And I would assume that the dash lighting would be controlled by the sensor on the dash, as they are with the 06s. (unless overiden by manually turning on lights)
